RCU Forums - View Single Post - Input Needed on TDL Model Systems Extra 330L
Old 04-30-2006 | 09:27 PM
mnrcaerobat
My Feedback: (197)
Default RE: Input Needed on TDL Model Systems Extra 330L
It is a nice flying plane. I lost mine when my transmitter rudder stick froze in the full left position.
There is a review online of the plane (here on RCU). I would recommend you reinforce the landing gear as stated in the article. I didn't and ended up rebuilding mine. If you wanted to, you could probably use some nylon screws in the gear and get by. I used some screws that were too small and short and had them fall out on a couple of rough landings. Then I installed some heavier screws and knocked out the bottom.
I flew mine with a Magnum 120 four stroke. THe motor box seemed too long for my four stroke. It was like three inches from the firewall and I ended up cutting it down because my four stroke was like five inches long and the cowl is only seven inches long.
I really liked the pull pull tail surfaces and the foam wings. I upgraded the cabling on the pull pull setup. I didn't think the supplied setup would handle this plane.
Overall, it flew really nice. Snap rolls were really cool and the inverted flat spins locked in real nice. I am considering getting another some day, as I have all of the gear needed to set another up.
