RCU Forums - View Single Post - Gas engine vibrations and throttle servos
Thread
05-01-2006 | 06:22 AM
9
av8tor1977
My Feedback: (
6
May 2003
7,245
Tucson, AZ
RE: Gas engine vibrations and throttle servos
Two setups for your review...
Whatever setup you use, try to keep the linkage as tight and slop free as possible. Otherwise you will have problems getting a reliable idle, and also if you set it for full throttle and there is slop in the linkage, engine vacuum can pull the butterfly
past
full open, closing the throttle partly and losing power. (Don't ask me how I know this...)
Some carb/manifold combos can be "turned over" as you mentioned to put the needles to the rear for easy adjusting, and some can't because the carb pulse hole is then blocked. Check yours because if the pulse hole is blocked, the pump in the carb can't pump fuel. If this is the case, you can drill and tap the pump cover on the carb, and route a hose to a fitting drilled and tapped into the crankcase to make the pump work.
It looks like Ken's setup in the picture above has a "twister" manifold. They cost around $15.00 bucks.
AV8TOR
Reply
Like
av8tor1977
View Public Profile
Send a private message to av8tor1977
Visit av8tor1977's homepage!
Find More Posts by av8tor1977
View iTrader Profile
