RCU Forums - View Single Post - 2 SPEED NEMESIS ADJUSTMENT
Old 05-01-2006 | 07:08 PM
fastlane7's Avatar
fastlane7
Default RE: 2 SPEED NEMESIS ADJUSTMENT
I had the same problem with mine out of the box, It was stuck in second throughout breakin. I'm used to the t-maxx so when I couldn't hear the truck shift i was confused. I started by turning out like you but ended up turning in instead. Follow the manual but turn both screws in even amounts until your stuck in first, then go 1/8 turn on each out until you get your desired shift point. I noticed it takes little adjustment to change it using 2 screws instead of one! Good Luck!
Has anyone had problems with clutch springs? I've managed to break 2 out of the 4 with not much run time at all! Any feedback would be appreciated! Thanks.
