5mm .8 pitch, about 1/2" (12.7mm for you metric measurement fans
) longer than the thickness of the prop, spinner backplate, and prop washer..
Too short and you can strip the hub, too long and the bolts will bottom before the prop is tight...Not a good thing...[
