DA150 Bolt Size?
Old 05-01-2006 | 10:06 PM
Fixed Wing's Avatar
Default DA150 Bolt Size?
What size and thread are the six bolts on the prop hub of the DA150? Thanks.
Old 05-02-2006 | 02:03 AM
Antique's Avatar
Default RE: DA150 Bolt Size?
5mm .8 pitch, about 1/2" (12.7mm for you metric measurement fans) longer than the thickness of the prop, spinner backplate, and prop washer..
Too short and you can strip the hub, too long and the bolts will bottom before the prop is tight...Not a good thing...[]
