RCU Forums - View Single Post - Gas engine vibrations and throttle servos
Old 05-02-2006 | 04:24 AM
The Raven's Avatar
The Raven
Default RE: Gas engine vibrations and throttle servos
Hi Av8tor,
Your first pic is very close to how I now envisage my throttle linkage as both the engine and carb orientation are like mine.
I'm attempting to add pics of my engine so you can see my setup. Hopefully you can see them here and they aren't too big.
What I intend to do is extend the lower standoff by adding a metal sleeve. The sleeve will become the mount/pivot for the bellcrank. Then a conventional setup back into the fuselage.
ID:	454275   Click image for larger version
ID:	454276   Click image for larger version
ID:	454277   Click image for larger version
