Flypuck,you can also solder on some fuel barbs if your handy at soldering.These are 1/8" inside diameter so they should just slip on over the existing brass tubing coming from the carb.Be careful not to damage any other parts of the carb that might be connected to the brass tubing due to thermal conduction.They are also available in a larger 5/32" size for larger size carbs.
http://www.shopatron.com/product/pro...d=DUB813/101.0
