RCU Forums - View Single Post - Wm Extra 300s 80''
Old 12-21-2002 | 02:19 PM
tivey
Default extra 300 modifications
O.K.I placed my rudder servo at the rear on left side of fuse to not have to use pull-pull.I attached a secondary rod to the rudder rod for the ohio superstar tailwheel that I installed.If the pictures turn out you can see this.I also did not do my sheel pants as they show. I used my dremel tool to create a slot in the bottom side.Hard to explain.I bought ultracoat and sealed my elevator and ailerons,so air leakage through was impossible.Also adds to strength.I used a dubro 24 ounce gas tank.Also mounted os160fx engine and used a bisson pitts muffler instead of factory muffler.I did not like the military stars and bars on a non military plane. Didnt seem appropriate.Tivey
