RCU Forums - View Single Post - Robart 605s
Thread: Robart 605s
Old 12-18-2002 | 01:01 PM
FlyingPilgrim's Avatar
FlyingPilgrim
My Feedback: (26)
Default Robart 605s
If the struts have the straight wire (below the coiled spring), just purchase some axles with set screws. They slide onto your strut wires and clamp in position with the set screws. File a flat spot on the strut wire after you get them in the right position (usually add 2 degrees of toe-in). Cut off the excess strut wire with a cut-off wheel on your Dremel tool.
