RCU Forums - View Single Post - Moki 2.10 questions
Old 12-17-2002 | 11:30 PM
PHILLCO's Avatar
PHILLCO
Default Moki 2.10 questions
MIKE: I HAVE BEEN RUNNING MOKI'S FOR SOME YEARS AND FOUND THE 210 WORKS WELL ON A 20/8 TOO A 20/10 PROP. PREFERABLY WOOD.
I HAVE IN THE PAST USED A OS TYPE
F GLOW PLUG BUT IF THE ENGINE IS BROKEN IN WELL I USE THE ENYA 3 WITH
EXCELLENT RESULTS. SOMETHING YOU MIGHT NOT KNOW IS THE MOKI'S USE FAI OR 5% FUEL ONLY. I USE WILDCAT PREMIUM FUEL ONLY. THIS HAS A 80/20
SYNTHETIC AND CASTOR MIX. IT WORKS GREAT. ALSO USE 5/32 FUEL LINE FROM THE CLUNK TO THE CARB. YOU WILL NEED TO DRILL OUT THE CLUNK TO 5/32 ALSO. I HAVE FOUND THIS COMBINATION TO WORK PERFECT.
HOPE THIS HELPS. IT WORKS FOR ALL THE MOKI'S I OWN AND ALL THE GUYS THAT FLY MOKI'S WITH ME.
