Moki 2.10 questions
Old 12-17-2002 | 09:07 PM
Default Moki 2.10 questions
I just picked up a used MOKI 2.10. What size prop should I use? I'm thinking 20x10 MA classic series as this is going onto a WM giant Mustang. Also, What glow plug works best. I have never had an engine of this size.
Very nice looking engine!!
Old 12-17-2002 | 11:30 PM
PHILLCO's Avatar
MIKE: I HAVE BEEN RUNNING MOKI'S FOR SOME YEARS AND FOUND THE 210 WORKS WELL ON A 20/8 TOO A 20/10 PROP. PREFERABLY WOOD.
I HAVE IN THE PAST USED A OS TYPE
F GLOW PLUG BUT IF THE ENGINE IS BROKEN IN WELL I USE THE ENYA 3 WITH
EXCELLENT RESULTS. SOMETHING YOU MIGHT NOT KNOW IS THE MOKI'S USE FAI OR 5% FUEL ONLY. I USE WILDCAT PREMIUM FUEL ONLY. THIS HAS A 80/20
SYNTHETIC AND CASTOR MIX. IT WORKS GREAT. ALSO USE 5/32 FUEL LINE FROM THE CLUNK TO THE CARB. YOU WILL NEED TO DRILL OUT THE CLUNK TO 5/32 ALSO. I HAVE FOUND THIS COMBINATION TO WORK PERFECT.
HOPE THIS HELPS. IT WORKS FOR ALL THE MOKI'S I OWN AND ALL THE GUYS THAT FLY MOKI'S WITH ME.
Old 12-18-2002 | 01:07 AM
Great! Thank you! Good to know about drilling out the clunk. Also good to hear about the low nitro fuel, that should save some $.
I planned on using a synthetic oil fuel. Any thoughts on that? I hate the tanishing affect of castor.
Also, what exactly does "FAI" mean??
Old 12-18-2002 | 01:40 AM
PHILLCO's Avatar
MIKE: I WOULD STRONGLY RECOMMEND 80/20 BUT THAT IS YOUR CALL. I HAVE FOUND THAT CASTOR REMOVES MORE HEAT THROUGH THE EXHAUST AND SAVES YOU IN CASE OF A LEAN RUN. I HAVE HAD ENGINES THAT I HAVE TAKEN APART FOR ONE REASON OR ANOTHER AND FOUND THE INSIDE LIKE NEW. I BELIEVE THIS IS DUE TO USING CASTOR BLEND FUELS.
IN REGARDS TO FAI. FAI IS A FUEL THAT HAS NO NITRO. THE EUROPEANS USE IT BECAUSE OF THE PRICE OF NITRO IN EUROPE IS SO EXPENSIVE.
I CAN SPELL WHAT THEY REALLY CALL IT, SORRY.
Old 12-18-2002 | 04:41 PM
Thanks for the info. Another question......how am I gonna start this thing. I don't have a $200 electric starter. Is hand starting safe?
Old 12-18-2002 | 09:06 PM
Flyfalcons's Avatar
Hers' how I start mine: Prime it till there's fuel coming out of the carb, then close the throttle and flip a few times. Then go to idle throttle and attach glow igniter. I use a chicken stick and hit the prop backwards against compression. If there is fuel in the cylinder it will fire. I can also start it by grabbing the spinner and twisting it backwards against compression. A good demonstration of that technique is shown on the H9 Edge video on www.3dbatix.com and is an acceptable method. Hope this helps.
Old 12-18-2002 | 09:31 PM
sawyer692,
I too have a Moki 210 and the instructions read that you must use fuel with some castor. It clearly says never use straight synthetic. I've been using 5% powermaster and the OS F plug (engine inverted).
Old 12-18-2002 | 10:10 PM
Hobbsy's Avatar
My Feedback: (102)
Default Plugs
It is interesting that you folks are using what is normally considered to be a four stroke plug in your big two strokes. My last two MDS engines, a .68 and a 2.18 both came with Hangar 9 Super Plugs which are fourstroke plugs also. Both have a really great idle with that plug. I run Fox 5% with 20%-50/50 lube in them.
