RCU Forums - View Single Post - HELP 911 THERE IS SOMETHING WRONG WITH ME RX!! (i think)
Old 05-07-2006 | 01:20 PM
H0ndaJunkie
Default RE: HELP 911 THERE IS SOMETHING WRONG WITH ME RX!! (i think)
If you can, try hooking up a 4.8v battery pack straight to the reciever. That way, you should be able to power-up and test your servos etc. If they still don't work, then you have a problem with your receiver.
If the servos work fine this way, but your ESC just beeps at you when you hook a battery up to it, either you need to place your throttle stick at zero throttle, or your ESC is toast.
Is it an Align ESC?
