RCU Forums - View Single Post - tachometer question
Old 05-09-2006 | 06:41 AM
BANJOAIRPLANE
Default RE: tachometer question
Also on that Hobbico tach,make sure you have the correct number of blades punched in.After you press the on button continue to press it until the number of blades your prop is.2 or 3.Try and put the sun at the rear of your plane and take a reading from front,or sun at the front of the plane and read from rear.
