RE: CG
Not all planes balance best at 33%. A trainer is usually better off closer to 25%. Once the pilot advances, the CG can be gradually moved back to 33% if so desired.
The further back you balance the plane, the more sensitive the elevator will be. Going from 25% to 33% is kind of like flipping on high rates on your elevator... sort of.
