CG
Measure the wing chord. Multiply that by 0.25 and 0.3.
These two measurements would be a good CG Range to start with.
Example: Chord = 12", dimension #1 is 3", dimension #2 is 3.6"
A good starting point in this example would be somewhere between these two points
Your wing chord is probably different so you have to do the math yourself.
Then dimensions pettit gave you are the distance back from the wing leading edge (LE) to the CG as measured at the wing root (where the wing touches the fuselage).
Not all planes balance best at 33%. A trainer is usually better off closer to 25%. Once the pilot advances, the CG can be gradually moved back to 33% if so desired.
The further back you balance the plane, the more sensitive the elevator will be. Going from 25% to 33% is kind of like flipping on high rates on your elevator... sort of.
G'day Mate, I have a senior Telemaster &I just checked the plans & the balance point is located at the centre of the main spar. What motor do you have in it, I have an old OS 61 FSR ABC. from the early 80s running a 12x6 prop, beautiful to fly, be aware a bit more down thrust is a good idea if your area has a wind problem. It helps the plane to penetrate in a good breeze.
Good Flyin Mate.
Allan.
Good Flyin Mate.
Allan.
ORIGINAL: LANNYBOB
all planes balance at one third back from the leading edge. measure the width of the wing at the fuesalge and take one third of that. there your balance point.
Thanks.
ORIGINAL: snys
Does this apply to tapered and swept wings? I don't think so, but am not sure. If not, how do you calculate for tapered wings?
Thanks.
ORIGINAL: LANNYBOB
Thanks.
another option is [link=http://sky.prohosting.com/air2/cg_calc.htm]here[/link].
