RCU Forums - View Single Post - Quick question guys!!!!!!!!!
Old 05-10-2006 | 08:28 AM
CENMANo6
Default Quick question guys!!!!!!!!!
I have a question about my Cen Subaru.......i was goin crazy trying to figure out the problem wit my car not shifting into second gear and i took apart the spur gears and all that other good stuff and notciced inside the second gear (the small gear i think) that there is a little peice that the clutch is suppose to grip onto.......but it is worn out......then i looked at the direction in which lil clutch thingy is suppose to spin and open up and drip the second gear it looks like its backwards......could the clutch be installed backwards??? or is it that the inside of the gear is just stripped due to normal wear and tear?? i know for a fact the motor is fine and its not a power problem so it has to be the clutch is installed wrong or just the 2nd gear is messed up. thanx in advace guys!
