ORIGINAL: Wizard61
Hey Dion,
A couple of quick questions. Are you using acid core, rosin core, or solid solder? Also, just out of curiosity, have you tried to weld one of these out of aluminum?
Keep going man, I'm right behind you.
James
James,
I'm using a standard rosin core solder. I have never tried welding aluminum although it does interest me a great deal. For aircraft above 25lbs or so soldered PC board will start to fail so welding aluminum would be the way to do.
I have some corrections to post, but I will keep it going![X(]
