RE: update on the new CS 061 RC engine
Sometimes if your brave enough and you have machines, you can make a heavy duty split collar to slip over the sleeve and slowly work the sleeve by tightening the split collar around the top to re-sized it and re-lap the piston.
This saves from trying to juggle pistons if you dont have a supply of them to mix and match.
