Futaba 9ZAP question? (new pics after first flight added)
Hi Craig
First off I do not have a 9Z yet but most dual rudder planes (with two servos) can be set up with a simple c-mix. Activate a C-mix and assign the master as "Rud1" or "rud" and then assign the slave (other rudder servo) as "AUX2". Activate it so it's on all the time at 100%. Make sure your extra rudder servo is plugged into the "Aux2" slot. By making expo & dual rate adjustment to "Rud1" the other rudder "servo" should follow exactly.
I use "Aux2" as an example only..not sure what the zapper calls them.
Perhaps I have misunderstood and have oversimplified this.
Not sure.
