Originally posted by locoworks
quite right ' sfaust'. i don't use dual rates on rudder, so it wasn't an issue for me. if it were too twitchy, i'd just drop the ATV on both chnl 4 and AUX8 . mixing would likely be the only way to achieve things an keep the dual rate or expo facility. i'm just lazy at programming mixes. well noted again sfaust.
Thanks...
What about the trim. When you adjust the trim on the rudder, does the Aux 2 channel track the trim changes, or just the rudder? I really don't know where they insert the trim changes into the software, whether its considered a stick input, or more of a mix input.
