RCU Forums - View Single Post - Dubro pull-pull system
Old 05-12-2006 | 01:21 PM
ehfleming
Default RE: Dubro pull-pull system
I use the rigging couplers to adjust the wire tension. Screw the coupler into the clevis; got to use Lock-Tite or they will turn out. I prefer the HD Safety-Lock clevis or Swivel Ball Links; don't need Lock-Tite with those. I suggest you run the wire through the crimp, through the coupler eye, through the crimp, loop OVER the crimp and run it through, again. If the crimp is too small to loop back through, cut short lengths of brass tube to use as crimps instead. I noticed the crimps that come with Dubro's .032" wire is sometimes too small to use. They were probably for the .020" wire. I hope this helps.
