RE: Matrix Setup
Front shocks #2 piston 45 Wt Losi oil. middle upper hole on the tower inner on the arms. Stock Springs.
-1.5 deg camber, middle ackerman hole, upper holes inside and out on camber links.
Rear Shocks #3 Piston 30 Wt Cen oil. middle upper hole on the tower inner on the arms. Stock Springs.
-1.5 deg camber, T3-S3 rear plate (also stock). upper inside hole on hubs one down inside hole on tower for camber links.
Diffs 5-5-5..
Can also try T2-S3 Toe plate. I use both.
This setup was used on the long and short chassis Pro cars, and should work good on the RTR as well..
