RE: Matrix Setup
Thanks for the setup Losmosis!
Questions for you Losmosis
Is the stock plastic rear suspension plate 3 toe in 3 anti squat? I thought it was 3 toe in and 2 anti squat?
You are using piston 3# for the rear shocks but what's the diameter on the hole? I didn't receive any 3# piston with my arr only 1 and 2, so I need to buy new pistons or just drill the old ones.
My arr is almost a PRO ( I think ), I don't have the pro chassis, the chassis braces and the radio tray in CF. I'm in the process to convert my arr to a pro.
Do you think I should buy the L or S chassis?
I will try some new setups when I get parts for my buggy (blow the front diff).
Jadda
