RE: Wild Hare Ultimate wing problems
There are several planes out there that will use all of the gear you've mentioned. Several will run great with the 58. Don't put it off because the WH didn't work out for you. Or, if you like the Bipe, maybe Tom could send you a piece of covering and the wood to make the fix it needs. (with an adjustment) I think after you get the plane in the air, you'll be happy you held on to it. It might make your wife feel better too.
