Hey Weedy, thanks for the input......do you use full throuttle on this? is the engine mounted inverted without a electric glow starter? I also need to know if you have had any issues with the Tail? Did you need to strengthen it in any way? I understand you have 3 tri stabs for additional support. And one more question...sorry about this....It's just I want to build this one right...
Did you use a pull pull system for your rudder setup or are you using just the push/pull? is the push pull adequate for full strength rudder control? I will be using hitec 425BB all around the plane.
Thanks for this.
Sal
