RCU Forums - View Single Post - Correct setup to Saito FA325R5?
Old 05-15-2006 | 03:17 PM
Ghostrider FIN
Default Correct setup to Saito FA325R5?
Hello
I have one problem with my Saito. I´m not sure what causes that some of cylinders dies. Cylinders fires again when i touch plug with glow wire. I think that i have correct mixture or (almost correct), i turn needle so that engine turns 20x10 Master at 6500rpm and then richen mixture that engine drops 300rpm. However one thing that i wonder is needle i need to turn it over 4.5 turns open that i get condition that i told above. Four and half turn is quite much i think. I tried to adjust mixture leaner but engine just loose rpm so i afraid that i turn engine too lean and turned mixture rich again.
I use Wildcat Helimix fuel with 10% nitro. There is 18% Klotz oil. I have Saito Plugs, do i need use some other pugs to front and others r
rear?
My engine is new only one gallon wildcat run trough, so i believe this may also causes problem.
What i should to do? If you have advise to me please tell it.
Here is video how engine runs if it helps something. on full throttle smoke comes a lot.Sorry big video, about 20MB
[link=http://www.students.oamk.fi/~t3pitu00/SAITO/MVI_0625.avi]Here is video, it should work now[/link]
