RCU Forums - View Single Post - Do I have a problem?
Old 05-15-2006 | 04:30 PM
DaveB
Default RE: Do I have a problem?
I think you have the slotted leading edge turned around. If I am not mistaken, the notches on the root end are different from the wing tip end. I believe there is an exra notch which would alter the alignment if it is on the wrong end. Turn it end for end and see if that makes a difference.
Good luck.
DaveB
