RE: Throw Rates?
The 15mm,30mm #s are the distance the control surfaces should move in each direction.Check them at their widest point with a ruler or a deflection gauge.If you have elevator halves on 2 servos,be sure they are traveling the same distance at the same time also.I just completed the BH Extra and their recomended throws are pretty aerobatic,although it called for more elevator than your Sukhoi
