RE: JR PCM rx and Futaba 601 Failsafe issue
The 601 holds and flies perfectly fine. The only oddity is in the lockout behavior. I need to get my hands on an oscilloscope to really see what is coming out of the RX.
I swapped out the RX. I substituted a different 649s RX. Even on a different channel. Same twitch. The gyro and the battery were the only things hooked up to the RX.
I tried a JR 770 RX. Same twitch.
I tried moving the gyro gain channel to different channels, same twitch. While I had the gain hooked up to a switched channel, flicking the switch would occasionally glitch it in exactly the same way.
-Mark
