RCU Forums - View Single Post - What Motor?
Thread: What Motor?
Old 05-16-2006 | 09:52 AM
ryan_t888's Avatar
ryan_t888
Default RE: What Motor?
Last summer I flipped it and blew out the receiver and ESC. I recently just pulled out the hull and it is totalled. It was a custom built cat hull out of insulation foam, this made it extremely light. Since it will dent with any type of impact it is extremely important to drive and transport it carefully. This problem is something I am willing to sacrafice for an extremely light weight hull.
It was 610mm(24" ) long by 229mm(9" ) wide. I would not want to go any smaller.
I am currently trying to rebuild/modify the plans I have made a while ago. So far I have a 3D model viewable in SolidWorks 2004. I saved the file in JPEG form so it may be viewed. There are a few changes I want to make to it yet. The setup inside from the back to front is going to be steering servo, 2 6-cell batts, motor, radio gear. Before hand I had the steering servo, motor, then batts.(rear to front) I could not get the CofG far enough back.
Ryan
