The only flow rate adjustment on the TME pumps is with a manual screw type restrictor that clamps over the line. Takes a couple of flights to get it dialed in just right, but the pumps work very well.
ORIGINAL: mrbigg
The local LHS just reopened and he has 2- TME Simple Smoke pumps on the wall. Do these work well and can you adjust the flow rate?
