RCU Forums - View Single Post - Opensource CDI ignition
Old 05-16-2006 | 08:51 PM
  #135
Mitty's Avatar
Mitty
Default RE: Opensource CDI ignition
You mean old code from [link=http://www.transmic.net/]transmic design[/link]? Thats where excell sheet with curves and source is?I ,so as a few others can't get excel sheet to work.Even though addins are all installed i still ger an error messages.Please anybody help
Thanks alot for advice!
Mitty
ORIGINAL: jmj
This is a new version of the CDI. The PIC is changed to a 16F628, and will be changed to a 16F88 soon.
The 16F88 is the best 16X PIC yet, lots of new possibillities, and an internal osc at 8 Mhz.
The 16F84 is outdated, and i guess we will not work more on the code for it.
The code is totally rewritten, and is now in C, and there is a new Excel sheet to manipulate the curve.
Nothing of this is released on the net yet, as it is still very much under construction.
The code works, and has been run on a real engine, but there are some bugs yet.
The hardware is also modified (by Bigboat), and under construction, but the new code/PIC16F88 will work on the old hardware with some modifications.
When this will be released is not decided yet, we have done a lot of work on the new CDI in the last month, but right now we have a little break...
For now, use the old code and the old schematics.
