RCU Forums - View Single Post - Throttle Problem
Old 05-17-2006 | 08:26 PM
DiTi's Avatar
DiTi
Default RE: Throttle Problem
first start from the control trims. on your controler you can find two buttons, one of them is the throtle trim. adjust that so it brings the accelerator to a neutral position. also. when you aply the brakes, the carb should remain at idle position, so adjust the spring on the accelerator and re-adjust the idle screw...
hope this helps
