RCU Forums - View Single Post - Throttle Problem
Old 05-17-2006 | 08:29 PM
ehroof
Default RE: Throttle Problem
center the throttle trim, then open (turn clockwise) the idle screw (small screw with spring under air filter) until there is a 1/8 inch opening, start it up and see if it run but not moving. if its to high, turn idle screw counter clockwise until its good.
