RCU Forums - View Single Post - U Can Do 3D 60 Building tips?
Old 05-18-2006 | 12:19 AM
3D_Tony
Default RE: U Can Do 3D 60 Building tips?
I have most of my UCD together.
I bought a Tru Turn spinner and the recommended adapter nut. It seems that there is going to be a problem with the length of the propellor shaft. With the prop, spinner back plate, nut, and adapter it appears that there is not enough room to fit the spinner. I thought I saw somewhere that someone recommended cutting off the propellor shaft (shorter). I hope that I do not have to do this!
Has anyone else used this spinner / prop / engine combination? Any advice would be much appreciated.
Also, thanks to everyone for their tips. Any other building or setup tips would be appreciated.
Tony
Update: 5/19/06
I was able to fit the spinner without cutting off the motor output shaft! I used the standard nut that came with the motor. The motor also comes with a jamb nut which I replaced with the spinner adapter. I only had to cut off about 1/8" off of the 10-32 side of the spinner adapter. Fits great now.
