RE: Mid Star 40 build questions
Do away with the dihiedral. 0-degrees of down thrust. Servo for each aileron. Be sure to balance plane left to right, not as forgiveing as top wing aircraft. Use .46 ball bearing..
Use some triangle stock on both sides of horz. and vert. stab to fusalage for reinenforement. Do not use cheap platic control rod clevis's that come with it.
