RCU Forums - View Single Post - PCM Required?
Old 05-18-2006 | 03:22 PM
DadsToysBG
My Feedback: (35)
Default RE: PCM Required?
You must set the fail-safe your self. The factory default is the last input. Mine is back to neutral and the engine to idle. Can't blame the fail safe if it isn't used correctly. For less then $30 everybody can have the idle with a plug in unit. Dennis
