RCU Forums - View Single Post - Throttle Problem
Old 05-18-2006 | 06:50 PM
jeepwrangler
Default RE: Throttle Problem
i dont know if this is right but when i use the break the spring has tension the it hits the alum. stops and pulls the rod back even farther pulling the carb shut and killing the motor ive tried the idle screw and that dont work either i was wondering if a shorter or softer spring would be better
