Align ESC problem
ALIGN ESC Problem: I have an Align RCE-BL35A ESC which came with my T-Rex (a brushless motor set-up). Works fine in the T-Rex which uses a Futaba radio. However, I want to use the ESC in an airplane; the airplane uses a Tower Hobbies "System3000" FM radio set with a dual conversion Rx. When I have everything hooked up, the servos work and the ESC sounds the single beep indicating power. There is no subsequent Rx recognition tone and the motor does not run. Since there is no Rx recognition I can not go into the program mode, either. QUESTION: are there some Rx-s which are not compatible with the Align ESC?
