RCU Forums - View Single Post - Brillelli 25 GT
Old 05-20-2006 | 08:38 AM
Scott Ellingson's Avatar
Scott Ellingson
My Feedback: (146)
Default RE: Brillelli 25 GT
Do you still need the plate I was going to send? Also were you sure to grind the tap flush on the inside? If it isn't it will hit the diaphram and may tear it, or at the least stop it from working propperly. If anyone else is having the same problem with it running good on the ground and going to crap in the air, let me know. I will provide a plate with a tap in it. Many engines do it in certain planes. BME is known for it. They actually sell a plate for $25 to replace it. We are going to install taps on all of them from now on so people do not need to do it. Just hook a hose up if needed.
Scott
ID:	464052   Click image for larger version
