RCU Forums - View Single Post - cox Tee-Dee .010
Old 05-20-2006 | 08:45 AM
rrragmanliam
Default RE: cox Tee-Dee .010
HI Scotty,
You cox .010 is an early one as GBC noted. It could be worth somthing to a collector if you have all the origional packaging and accesories and they are in decent condition. I think the engine came with a fuel tank back plate (on the engine), a non fuel tank type back plate (fou use with an external tank), a wrench, a propeller, instruction sheet, and I've even seen some with small COX stickers. If all this came in a clear plastic jewel type box then it's one of the most sought after "tens". Most go for about 70 to 90 bucks on ebay.
You could also fly the thing. With todays micro gear there are pleny of options. Heres a pic of a Radical RC Micro stick I have with a COX .010
3 channel Elevator, Aileron, Throttle- (Thank you Mr. Adams)
Darren
PS Oooooopss, I just noticed in your origional post that you said you didn't have the instruction sheet. I'd be happy to mail you a set if you PM we with yor address.
