RCU Forums - View Single Post - Is the bottom end too lean?
Old 05-20-2006 | 09:48 AM
voborild
Default RE: Is the bottom end too lean?
Mind you I'm a newbie at this, but I thought the same thing when I read the manual. I did lean it out some and then the dead sticks started. We thought we should back it off some and now it dies during ground check when transitioning from idle to full.
Maybe I over adjusted each time? If so, what is a good starting point to readjust from there.
