RCU Forums - View Single Post - regulator question
Old 05-21-2006 | 01:22 PM
rrritchey
Default RE: regulator question
Hi,
You can use just one of the inputs but I would suggest you use both of the outputs to your receiver. The reason is that it provides a dual current path and will reduce the voltage drop though the wire and connectors into your receiver. The result will be more torque from your servos. Please let me know if you have any other questions.
