RE: Do I have a problem??
If you use the 22x12 with the 13XL, your amp draw will be very high and the motor will run at a higher temperature.
If I were you, I would use the 13XL with the 20x13. This combo does make your plane fly a little bit faster than with the 14XL/22x12.
