RCU Forums - View Single Post - servo twitching problem?
Old 05-22-2006 | 12:47 PM
3dhehe
Default servo twitching problem?
Hi guys, ive recently put together a 3d plane, and was all set to go when i noticed that as i moved one of the control's (aileron) the elevator servo begins to twitch now and again, when i let off the aileron control, every thing is fine again. The rudder also twitches slightly when the aileron is on full.
(i have my tx set up so aileron and elevator are on opposite sides)
The aileron servo makes a buzz now and again, when its on full, then stops after a few seconds, it doesn't buzz when i disconnect the control horns, but it still causes the other servos to twitch, also the ailerons move very smoothly, and plenty enough in both directions, so i dont really see why it buzzes when connected.
I have used this same set up but with hs-81's with no glitches at all. Under normal circumstances id just swop the servo, but ive had to glue them to the plane, so if any one has any ideas, as to where the problem may be coming from, it would be great to hear from you.
The gear im using is as follows.
TX Futaba T6EXA
RX JR R700
Servos hitec hs-65 hb karbonite
Thanks in advance
Joe
