you will toast the bottom end if you keep it as is, you need to change it like redfox says, the muffler to the tank pressure and the crankcase to atmosephere, just hang it out the bottom.
the crankcase gets its oil from blowby and if you stop the flow out of the crankcase you stop the oil
