RE: How do canards work???
With the jet legends model you don't get a manual.... So If I put in about 10 degrees up in the canards and mix it with the elevator, about how much down should I start with in the elevator?? I hoping that this set up will slow the jet up for landings. I sure thank you for the suggestions...........
Thanks again
Hoss
