RCU Forums - View Single Post - This guy can fly!
Old 05-22-2006 | 05:14 PM
Benoit
Default RE: This guy can fly!
ORIGINAL: bla bla
Greeting oh great one. Fantastic inspiring flying Benoit, just wonderful.
Tell about your plane and setup if you would, motor, prop, batteries etc etc.
What about the design, have you published it?
What about trimming... I would imagine that the airframe is a great deal more ridgid and thus stable because of the aerofoil section and the box body instead of the typical flat foam wing and fuz.
Thats something that interests me great as my foam flaties need retriming all the time and are some what difficult to do anying near as precise as what your managing.
you really have opened up the possiblity and shown us pattern fliers that we can find an airframe that lets us fly the type of style we like with a foamy.
Up until now we just been messing around with them.
Now dought you will have seen that at the E-TOC!
About the fusion set-up: 97cm wing span, lenght 105cm , weight 230/250gr with 3x li-poly Kokam 340 to 640, motor AXI 2204/54 GOLD LINE, prop GWS 9/5, Phoenix 10 controler from Castel Creation, 6x waypoint (6g) servos ( 2x ailerons, 1 elevator, 1 rudder, 1 thrust vectoring) + 1x 4gr servo for streamers), GWS6ch 72Mhz receiver (modified to 7Ch)
Indeed, the plane is very solid and precise on the trajectory if you can hold some speed. Nevertheless, for F3P, a biplane like my Mystic (Donut's model) will be more efficient.
But the Fusion is more reactive for freestyle, especially with the Thrust vectoring system which give a terrific yaw control. The motor is on an axe (or gimbal), and it's just mixed with the rudder. It's difficult to make a kit with such an airfoil. The plane is fast and fragile. But we are working on it. May be a 10% smaller plane will be better. Stay tuned!
ID:	465207   Click image for larger version
ID:	465208   Click image for larger version
ID:	465209   Click image for larger version
