RCU Forums - View Single Post - 4* .40 doesn't roll good help
Old 05-23-2006 | 08:48 AM
Commander_Drake
Default RE: 4* .40 doesn't roll good help
It should not pull left when you throttle up. Somthing is misaligned (or warped). Check it over carefully, with an incidence meter if possible. Make sure you dont have any left offset in the engine mount. Post some pictures if you can.
