RCU Forums - View Single Post - Dz Bench Run
Thread: Dz Bench Run
Old 12-21-2002 | 01:50 AM
earl williams
My Feedback: (27)
Default Dz Bench Run
RAN IT FOR THE FIRST TIME TODAY, AND WOW! IT IS EVERYTHING I HEARD IT WOULD BE AND MORE. TURNED APC 18X6WIDE 9400 RPM WITH THE RICH 2 TURNS OUT FOR BREAK IN. NORMAL WOULD BE 1 - 1 1/2 TURNS. SO THERE IS MUCH MORE RPM TO COME. IT TURNED 8500 AT HALF THROTTLE. I WILL KEEP IT BETWEEN 8000 - 9000. WILL TRY A 19X6WIDE. I WILL USE IT IN A 3D APPLICATION. I USED MAGNUM #1 FUEL.
I DID NOT HAVE TO USE A STARTER, JUST FLIP IT A FEW TIMES WITH THE THROOTLE WIDE OPEN, BACK TO IDLE AND BACK FLIP AGAINST COMPRESSION. SATARTED AS EASY AS MY SAITO 100 DID. I USE A PAINT ROLLER COVER FOR MY CHICKEN STICK. THE VIBRATION IS VERY LOW. BREAT ENGINE!
